3D Design
3D Design
License server down? High priority!
    • paul pladet
      Hello,   Multiple customers have called us that they cannot login on SpaceClaim. They get the following error (see image) I have already tried to offline activate their license, but without succes.   Can this be solved ASAP?
    • Subashni Ravichandran
      Hello Paesc
      Thank you for informing us of this issue.
      We have received similar complaints from other users as well.
      I have escalated this issue with my team to check for issues at our end.
    • nicolas bouley
      same error here
      please give a feedback.
    • Naresh Patre
      Hello Paesc nicolas
      The license issue has been fixed. Please refresh the license as per below steps and launch SpaceClaim:
      1. Open Command prompt in admin mode
      2. In the command prompt, type in:
        cd C:Program FilesANSYS Incv211licensingclientwinx64
      3. Once in that directory, run the following command:
        ansysls_client.exe -RefreshLicenseEntitlements
      Please let me know if you face any issues further.
      • nicolas bouley
        Naresh Patre
        problem solved
        Thank you.
  • The topic ‘License server down? High priority!’ is closed to new replies.
