3D Design
3D Design
License required to solve: mechanical pro or higher. ansys discovery enterprise
    • paul pladet
      I am running Ansys Discovery Enterprise, but when i want to use the Refine mode i get the following error:
      Ansys Discovery Enterprise should be enough to use this mode right?
    • Rajeshwari Jadhav
      Hi Paul,
      Can you launch Discovery> File> Settings> License and share screenshot of it.
      • paul pladet
        See here:
    • Rajeshwari Jadhav
      May I know if you have a shared web license or floating licenses for Discovery?
      • paul pladet
        I am running both, but have set the priority to floating in the licensing settings.
    • Rajeshwari Jadhav
      Hi Paul,
      It's working for me with Discovery Enterprise license only, please rename the Discovery and Ansys folder under %appdata% to Discovery.old and Ansys.old.
    • paul pladet
      I have done this, but i got the same error:
    • paul pladet
      Could someone please respond? I am still stuck with this issue.
    • Rajeshwari Jadhav
      Hi Paul,
      Please escalate this case through your Account Manager I will work with you internally.
    • benjamin
      Hi Rajeshwar,
      We cannot escalate this threw the Account Manager cause we dont have access for it or if we have access for it, we dont know how.
      Please a solution under this topic or contact us directly: Support@aesc.nl
    • Tim Dukes
      Hi Ben, Mech Pro or higher and CFD Pro or higher is now needed to use the 'refine' mode. Discovery enterprise only gives access to Explore Mode + Live GX solver in the refine mode for certain things.
Viewing 8 reply threads
