November 9, 2022 at 9:59 pm
cherishbauer
Subscriberupgraded Ansys license manager to 2022r2 and now unable to get Ansys software to see license, old version of Ansys has no problems pulling a license. Ports have not changed, is it possible Ansys license being used isn't compatible with 2022r2?
November 10, 2022 at 2:27 pm
George Karnos
Ansys EmployeeCheck your license file for TECS Date
Example:
Looking at the increment lines in your license file:
INCREMENT preppost ansyslmd 9999.9999 31-jul-2023 10Â9999.9999 would be the TECS Date (Only programs created on or before this date will be able to use this increment)
31-July-2023 - Expiration Date10 TASKSOR:
INCREMENT agppi ansyslmd 2020.1014 permanent 6
2020.1014 - Only programs created on or before October 14, 2020 will be able to use this Increment
Permanent - no expiration
6 TASKSMore than likely: 2022 uses the ansyslmd.exe communication.
Older versions use the ANSYS Interconnect.
Please check the firewalls to ensure access to the licensing port 1056 as well as 1055 and 2325.You can set ansyslmd to a static port 1056 by adding it in the license file on the VENDOR line.Â(c:\Program files\Ansys Inc\shared files\licensing\license_files\ansyslmd.lic)(/ansys_inc/shared_files/licensing/license_files/ansyslmd.lic)ÂFor example:VENDOR ansyslmd PORT=1056ÂAfter doing so, restart the license manager.
Now try to run.
If it does not, check the %TEMP%\.ansys directory for licdebug file erors for the program trying to be run.
$HOME/.ansys for linux
- The topic ‘license manager 2022 r2 issues’ is closed to new replies.
Ansys Innovation Space
1414
1220
1118
1015
