July 23, 2024 at 1:29 pm
agarciac
SubscriberHello,Â
After updating my ansys lumerical version from 2024 R1.3 to 2024 R2 I've started getting license issues when I save many jobs to the job queue an then run runjobs. About 20% of them fail with the following error:
GPU streaming multiprocessors(SMs): 40System error: 10054 "An existing connection was forcibly closed by the remote host.".ÂError: Failed to checkout feature 'lum_fdtd_solve'
Would you like to reconfigure your license settings?, Response: NoLicense error: Failed to checkout feature 'lum_fdtd_solve'System error: 10054 "An existing connection was forcibly closed by the remote host.".ÂError: there was a failure with the license. Process number: 0 had this errorÂThe license for lumerical is hosted on a server if that makes any difference. Additionally, this is an error that only occurs with 2024 R2. I can still run 2024 R1.3 without any license failures.Â
I was wondering if anyone else is having this issue or if there is a way to solve this.ÂThank you for your help!ÂÂ -
July 23, 2024 at 5:24 pm
Lito
Ansys EmployeeHello Andres Garcia Coleto,
- Try to reset/delete the 'FDTD Solutions.ini' file from your user's folder before running with the 2024 R2 release.
>>Ansys Lumerical product preference files – Ansys Optics - Should the issue persists, please assist us with the following:
- Which operating system and version are you running?Â
- Please send a screenshot of the Optics Launcher > Licenses configuration utility.Â
>>Lumerical license configuration with the Ansys Optics Launcher – Ansys Optics - Also a screenshot of the Lumerical CAD > Resources configuration.
>>Resource configuration elements and controls – Ansys Optics - Are you runnning FDTD on GPU?
- Check if the license manager (LM) status and availability from your local computer.
>>How to check license status and availability – Ansys Optics
Check/verify that the LM is up and running and have the licenses required to run your simulation with GPU.
(40 SMs, requires 3x FDTD solve licenses)Â
I look forward to your reply soon. Thank you!Â
- The topic ‘License issues with newest 2024 R2 Version’ is closed to new replies.
