LS Dyna
LS Dyna
license issues and release when using dynain and case
    • Dennis Chen
      Hello, when using *CASE methods to run multiple cases, i am running into some license issues where the completing 1st case wouldn't release the license for the 2nd case.   How can one get around this in a situation where we only have one working solver license for Dyna?
    • igandiko
      As a workaround, could you please try using a script to run the cases sequencially? For example, the script could have below two lines.
      C:\path\lsdyna.exe i= input.k CASE=1
      C:\path\lsdyna.exe i= input.k CASE=2
    • Dennis Chen
      Hi Imtiaz, i didn't get any email notification from your reply.   I should get notified if it's my post, correct?
      Anyways, thank you for your response.
      • igandiko
        Yes, you should have received a notification. Please let me know if you did not get an alert for this response too. You can also try clicking on the bell icon on the top.
