March 16, 2021 at 5:56 pm
Kadhir
SubscriberI have a commercial license-1 for enterprise. Every time I use my solver and close the solver, it shows that already the license is being in use. Is there any way to clear the license manually when not in use?(using client)n -
March 17, 2021 at 4:29 pm
Kadhir
SubscriberThe solver that I am using is Mechanical APDL and license is Enterprise for Non linear analysis. Every time I close the solver that is complete solution, the license get stuck in and I am unable to do another Ansys. It works sometime if I close the computer and open again. I wanted to know if I could manually release the license somehow.n n -
March 17, 2021 at 4:57 pm
Forum ModeratorThe licence should release when you close the solver down. will know what stuff to ask for. n -
March 17, 2021 at 5:31 pm
Kadhir
SubscriberCan you help me with this license issue. I need to know, is there any way that we can manually disable the license? Thank you in advance.n -
March 18, 2021 at 11:15 am
ANSYS_MMadore
Forum ModeratorPlease exit all Ansys applications and check for any stuck ansysli_client or ansyscl processes in your Task Manager. If you find any, please kill them to try freeing the license.n -
March 18, 2021 at 5:41 pm
Kadhir
SubscriberThank you for your response. I tried to take your method. I closed everything related to Ansys. I find my license is still stuck in ansysli_client but, there is no ansys processes in my task manager. How can I kill them ?n -
March 18, 2021 at 6:47 pm
ANSYS_MMadore
Forum ModeratorArrayIf there are no hung processes, you would need the license server administrator to either restart the license manager or to run the lmremove command to release the license. n -
March 18, 2021 at 6:50 pm
Kadhir
SubscriberAh I see,so there is no other way to do this without administrator releasing the License from the License manager. Thank you very much. that was very helpful.n -
March 18, 2021 at 7:38 pm
Amine Ben Hadj Ali
Ansys EmployeeWelcome.n
Viewing 8 reply threads
- The topic ‘License get stuck every time after solver has finished running.’ is closed to new replies.
Ansys Innovation Space
1414
1256
1118
1015
