Ansys Free Student Software
License Error: FlexNet Licensing error: -88,309 – How do I fix it?
    • Fum4sz4
      Hi, I am a new user of the software. I downloaded Ansys Student 2020 R2 a few days ago but I couldn't make it work.
      I have tried to reinstall it several times but no success. Every time I try to use it this error appears.
    • ANSYS_MMadore
      Please refer to this post for guidance.n/forum/discussion/897/license-manager-error-aa-t-in
    • Fum4sz4
      I tried the method of finding the files with a future date, but it has system files, and the amount of files I found is huge. Is there any software I can use to make these changes at once? I still have the issuen
    • ANSYS_MMadore
      There are some tools available online. Care should be taken with modification. I would recommend searching how to fix flexnet error 88 on Google.n
    • Fum4sz4
      I tested several programs that promise to solve the problem. I tried several methods to solve the problem and nothing worked. The only way I could do to solve it is to change the Windows date to a future date (2021). If someone has a different solution, please help me. I don't know if this can affect any other software tool. n
    • Fum4sz4
      After a lot of searching, I finally managed to find a solution to my problem. nI installed the Attribute Changer for Win10, researched all the softwares of my system that use the FlexNet system, forced the closing of all the operations by the Task Manager. I did the search in C:by date and specified the interval from 09/22/2020 - 01/02/2021. I organized by Modification Date and selected all files and folders that had a date after the current date (09/22). I followed this tutorial:https://www.online-tech-tips.com/computer-tips/how-to-change-the-last-modified-date-creation-date-and-last-accessed-date-for-files-and-folders/#:~:text=File%20Properties%20tab.-,If%20you%20want%20to%20change%20the%20last%20modified%20date%20or,these%20using%20the%20options%20providednIn case the use of external links is not allowed, I apologize, but it was the only solution I could find.
Viewing 5 reply threads
  • The topic ‘License Error: FlexNet Licensing error: -88,309 – How do I fix it?’ is closed to new replies.
