November 12, 2020 at 3:51 pm
AStumpf
SubscriberHello,
I have following error:
November 16, 2020 at 2:27 pmANSYS_MMadore
Forum ModeratorArray Can you please try renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old, where XXX is the version of ANSYS you are trying to run?.Thank you,nMattnNovember 25, 2020 at 11:06 amAStumpf
SubscriberThank you Matt,nbut this does not solved the issue.nKind regardsnArnenNovember 25, 2020 at 3:12 pmAStumpf
SubscriberHey,nthere was missing the systemvariable: LM_PROJECT.nI do not know why, but to add the variable solved the issue.nThank for your effortnArnennNovember 26, 2020 at 4:13 pmEricmonroe
SubscriberAlso I recommend view this review https://differencebtwn.com/difference-between-dissertation-vs-thesisnViewing 4 reply threads- The topic ‘License error: -5, 147’ is closed to new replies.
5059
1770
1387
1248
