3D Design
3D Design
License error
    • Roberto
      Hello  Charudatta Bandgar
      I have a customer who has renewed the license, every time he now closes SpaceClaim he gives him the error that the license is not valid, how can I fix it?
      We have already tried in other PCs and the error is the same.
      Send files and videos privately
      2022/12/06 10:39:19 ...WARNING: Because no license files were found in the following location, the 'ANSYS, Inc. License Manager' service was not able to be started.
      C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files
      The ANSYS License Management Center's 'Add a License File' link should be used to install license files and to start the ANSYS, Inc. License Manager.
      This can be accessed through the 'ANSYS, Inc. License Manager --> ANSYS License Management Center' item in the Windows Start menu/Apps page.
      Regards
    • Charudatta Bandgar
      Hello Roberto
      Let me check.
    • Roberto
      Do you have any news about the licensing problem? Can you fix it?
      Regards
    • Roberto
      Good morning and happy new year, I am writing to find out if the problem has been solved, I am waiting for a reply
      Regards
    • Roberto
      Hello Devendra Badguja
      Charudatta Bandgar
      The customer would like an answer otherwise he will no longer renew the license, 1 month has passed since he reported the error
      Regards
      • VJ
        Roberto Can you share a copy of the license file for review? Thanks.
    • Roberto
      Hello Vijay Prithiv
      This morning I tried again and it no longer gave me the error on both PCs, if it happens again I'll tell you something.
      1 pc is windows 8 and therefore I know that SpaceClaim is not compatible therefore the error could also be corrected, but on windows 10 it had to go without problems.
      I sent the files to charudatta.
      For now the problem is solved because today it didn't give any problems, if it happens again I warn you
      Regards
Viewing 5 reply threads
  • The topic ‘License error’ is closed to new replies.
