August 27, 2020 at 8:34 pm
jerpot94
SubscriberI have referred to the instructions below and I am trying to renew my Ansys license
August 28, 2020 at 10:56 pmtsiriaks
Ansys EmployeePlease install some uncompessing tool like 7zip, winrar, winzip, etc., to help with the extraction. nYou may also need to reset the file association so it isn't default to Notepad. If you are not sure how to do this, search online on how to reset Windows file association nAugust 31, 2020 at 1:58 amjerpot94
Subscriber#tsiriaks, Thank you so much for your reply, I appreciate it.n Will it be okay if I uninstall my current 2019 R3 version and then download and install the 2020 R2 version, will that work on my machine?nSeptember 1, 2020 at 9:26 pmtsiriaks
Ansys EmployeeYes, it should work. You don't even have to uninstall 2019 R3, you can just install 2020 R2 on the same folder. It will separate the versions to different foldersnSeptember 3, 2020 at 12:09 amjerpot94
SubscriberThank you so much.nSeptember 4, 2020 at 12:36 amtsiriaks
Ansys Employeeyou are welcomenViewing 5 reply threads- The topic ‘Licence Refresh without changing the version of ansys’ is closed to new replies.
3572
1188
1076
1063
952
