November 14, 2020 at 8:12 am
Mugisha1
SubscriberI downloaded the current student version of ANSYS and unable to run packages like CFX . whenever I click on CFX pre to load a new workpage , I end up getting this (Licence checkout failed!
I also realized I do not have a license yet I downloaded a student version .
Please help me !
Thank you
November 16, 2020 at 2:33 pmANSYS_MMadore
Forum ModeratorArray Can you please provide screenshots of the %TEMP%\.ansys\licdebug.CFX_PRE.202.out and %TEMP%\.ansys\ansysli_client....log files?.Thank you,nMattnNovember 17, 2020 at 6:58 amNovember 17, 2020 at 2:14 pmANSYS_MMadore
Forum ModeratorIt looks like you are not running a regular Student installation. You actually should not have an ansysli_client....log file with the Student installation. Do you have any other ANSYS products installed? Can you open a command prompt and type set without the quotes and post the full output? Can you share a screenshot of your C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing directory?nNovember 17, 2020 at 2:44 pmNovember 17, 2020 at 2:46 pmANSYS_MMadore
Forum ModeratorThere should be more to the output than what you posted, can you scroll up in the Window?nNovember 17, 2020 at 2:52 pmNovember 17, 2020 at 2:53 pmANSYS_MMadore
Forum ModeratorPlease remove these 2 variables.nANSYSLI_ELASTICnANSYSLI_LCPnnThanksnMattnNovember 17, 2020 at 2:54 pmMugisha1
SubscriberCan you share a screenshot of your C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing directory? - I can not get to the Licensing directory using this path unfortunately .nViewing 8 reply threads- The topic ‘Licence checkout failed’ is closed to new replies.
4904
1588
1386
1242
