October 10, 2024 at 10:34 pm
October 11, 2024 at 10:42 am
Rajeshwari Jadhav
Forum ModeratorHi,
It should not ask for license for student free version, please check if you have ansyslmd.ini file under C:\Program Files\Ansys_Inc\Shared Files\Licensing. If yes then rename/delete it to ansyslmd.ini.old.
October 11, 2024 at 4:55 pm
pa.fidalgo
SubscriberHi, i do not have that file under that directory what should i do?
October 11, 2024 at 5:01 pm
Rajeshwari Jadhav
Forum ModeratorHi,
If file doesn't exists, you can check on set an alternate preference and click on ok.
October 11, 2024 at 6:06 pm
October 14, 2024 at 4:31 pm
Rajeshwari Jadhav
Forum ModeratorHi,
May I know which version have you installed? student free version or academic, if academic then please point to the server first through Ansys Licensing Settings(launch it as an admin).
November 27, 2025 at 3:11 pm
nasiba
Subscriber *Global - Messages
 [info] GRPC server running on port: 50051.Â
Artificial Magnetic Conductor (AMC) (C:/Users/Nasiba/Desktop/)
 [error] Shared Web checkout call to LicensingSettingsUtility for 1 tasks of electronics3d_gui, hfss_gui failed  Error Detail  User "nasiba@bupt.edu.cn" is not recognized and/or is not associated with any account  Status code  403  Help URL  https  //laas.ansys.com/v1/error/unrecognizeduser  Diagnostic Detail  UserNotRecognizedError; Please verify that user "nasiba@bupt.edu.cn" is associated with at least one account in the ID Portal; Operation Id  70c3210042cb459da622364aca523f7e   (11:03:18 PM  Nov 27, 2025)
 [info] The following designs have been opened in read only mode: HFSSDesign1. Read only mode can be enabled and disabled for different design types in the General/Project page of the General Options dialog. (11:03:19 PM  Nov 27, 2025) . *Global - Messages
 [info] The following designs have been opened in read only mode: HFSSDesign1. Read only mode can be enabled and disabled for different design types in the General/Project page of the General Options dialog. (11:03:19 PM  Nov 27, 2025)-
November 27, 2025 at 4:31 pm
Rajeshwari Jadhav
Forum ModeratorPlease create a new post for your issue
5639
1885
1403
1303
