Electronics
Electronics
Layout not visible
    • Dwight Bragdon
      I am having an issue getting the layout view of a circuit to be visible.
      As shown below, the layout view shows only the connection nodes with no components.
      I have to assume I'm overlooking something simple.
      I am running version 19.0 and would appeciate any suggestions.
    • Praneeth Munaga
      Thank you for reaching out to the Ansys learning forum.
      The version mentioned is quite old. If possible, please use any of the latest versions as it is enhanced with significant improvements.
      Kindly check if you facing the issue with this model alone or with all the models.
      Best regards,
      Praneeth,
      Click here to join Electronics Community and build a network.
