March 28, 2020 at 3:59 pm
March 30, 2020 at 5:00 am
Keyur Kanade
Ansys EmployeePlease post the questions in appropriate category. Moving this question to other category to get better response.Â
Moving to installation category.Â
April 1, 2020 at 12:07 am
tsiriaks
Ansys EmployeeOpen CMD Prompt and enter the following command
"%awp_root201%fluentntbinwin64fluent.exe" 3d -g -t0
does this launch Fluent ?
Also, do you have install.err file under C:Program FilesANSYS Inc ? If so, please post its content here.
April 3, 2020 at 10:45 am
Ahmed1400
SubscriberThank very much for replying...
1. I tried this command "%awp_root201%fluentntbinwin64fluent.exe" 3d -g -t0 but it does not work, and I did not find a folder with this name (install.err)
2. + the fluent, also I can not open CFX 2020 R1, and also Watertight Geometry Workflow.... and others apps.Â
the version I used is Student version 2020 R1.
Ex: These messages I got when I tried to open CFX
April 6, 2020 at 8:00 am
Ahmed1400
SubscriberAny Help Mr. Tsiriaks
April 7, 2020 at 12:33 am
tsiriaks
Ansys EmployeeOpen CMD Prompt, then type
set
and post the output of it here
Also, the install.err is a file, not a folder. For your case, it should be under C:Program FilesANSYS IncANSYS StudentÂ
April 7, 2020 at 10:02 am
Ahmed1400
Subscriber1. Below is the output
2. I searched the file install.err but I didnt find it.
April 10, 2020 at 1:06 pm
April 10, 2020 at 11:40 pm
tsiriaks
Ansys EmployeeYou mean you reinstall the OS ? That's pretty extreme but glad it helps with the issue.
This looks fine to me but if things are bigger than you expected, it may have something to do with your computer display settings. See if it's at default scale (100%) , also check your display resolution setting.
Thanks,
Win
April 15, 2020 at 12:16 pm
Ahmed1400
SubscriberYes IÂ reinstall the OS.Â
I changed the  display settings and now it looks very fine.Â
Thank you very much WinÂ
April 15, 2020 at 11:29 pm
tsiriaks
Ansys EmployeeYou are welcome ! Glad to hear all is good for you now.
Win
- The topic ‘Launcher.exe – Entry Point Not Found………… Could not be located in the dynamic link library…’ is closed to new replies.
3079
977
907
858
792
