March 13, 2020 at 12:14 am
Masri
SubscriberHi guys,
I need to study a torsional buckling of I-Beam... but I have a big problem with creating the model ... you know thers is tow option :
1- beam as line body model Â
 i am facing a problem when i want to apply the Distributed force .... I dont want to apply the force always direkt on the line body but on the upper flange like the pics ,,,,,,,Because this case gives the lower load multiplier as the case when force applied direkt on the line bodyÂ
2 - as Solid object
the load is here applied on the upper area ..... in this case i cant applying the load at the center of section (in The opposite of the first case)
could you helping me please .....I just want to adjust the point of distributed load along the line shown in the first image(3 cases)
Regards
Masri
March 13, 2020 at 7:27 am
Aniket
Forum Moderatorwhy you can't apply load on center in the solid model case?
just create a named selection using the worksheet for the nodes at the center (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_NS_Criteria.html) and apply it using nodal force (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_Nodal_Force.html).
-Aniket
March 13, 2020 at 12:08 pm
Masri
Subscriber Hi Aniket ...... how can i chose the center of this I section to apply the distributed load for the casses shown in the pic?
the links thar u shared dont open because i have not a custumer accoutÂ
RegardsÂ
Masri -
March 13, 2020 at 4:32 pm
Aniket
Forum Moderator -
March 13, 2020 at 9:50 pm
Masri
Subscribernot related to my problem .... sorry
March 14, 2020 at 2:55 pm
Aniket
Forum Moderatorcan you explain how it is not related to your problem?
March 14, 2020 at 9:37 pm
Masri
Subscriber -
March 15, 2020 at 8:10 am
Aniket
Forum ModeratorMasri,
I had understood your query in first thread, and the (named selection with worksheet) and (nodal force) are the only two things that you will need to filter out the nodes at the center of the section without needing to split the geometry in geometry modeler.
following video explains it for faces, you should be able to do the same for the nodes as well.
https://www.youtube.com/watch?v=ByVtViHQTMA
March 18, 2020 at 9:03 pm
Masri
SubscriberHi Aniket,
sorry for my late replying
I was busy with the critical situation due to the Corona virus in my city , However I divided the solid body in Design modeler causeI could not catch the points located on the body center line ,So I divided the solid body into two parts as shown in the pic
how can I choose the surface resulting from the division in order to apply the force on it (The surface shown in the image above)Â ..... selecting by suface did not recognize it ... can u help me to solve this problem?
Regards
Masri -
March 21, 2020 at 7:31 am
Aniket
Forum ModeratorI hope you and your loved ones are safe and sound. Did you watch the video in previous post? It selects faces and applies worksheet criteria to select the faces that fall in similar criteria. Like I mentioned before you need to select nodes and apply criteria in worksheet. Fiddle around a bit in the named selection you'll understand what I mean.
Now you have sliced the geometry, so you already have two surfaces at that location. So create a multibody part with shared topology in design modeler so there is a single face shared by top and bottom body. And then simply hide one body and select the face.
March 24, 2020 at 7:20 am
Masri
Subscriberthnx Aniket... that was the solution. It remains only to evaluate the results because the results differ greatly from manual calculation. I will open a new discussion to figure that out ,,,,
RegardsÂ
Masri
- The topic ‘lateral–torsional buckling … problem with creating the right model’ is closed to new replies.
4607
1515
1386
1209
