TAGGED: ansys-mechanical, ansys-thermal, laser, laser-heating
January 2, 2025 at 8:14 amAdSubscriber
Hi, I want to simulate tensile tests of specimens subjected to laser texturing patterns (like dimples or linear grooves on the surface through laser). I don't know how to perform laser surface texturing in Ansys. Any help in this regard will be much appreciated, please.
Thanks
January 9, 2025 at 11:16 amRahul KumbharAnsys Employee
Hi Ad,
If I am assuming correctly, you want to analyse the specimen which has grooves /geometrical depressions due to laser process. If correct, you can just cretae a geometry with such grooves/depressions and simulate it in Mechanical. You can use Spaceclaim/Discovery to create such geometry. Following post has one example of embossing. Similar method can be followed to create grooves
https://innovationspace.ansys.com/knowledge/forums/topic/projecting-text-onto-a-curved-surface-and-embossing-and-engraving-in-spaceclaim/
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Script Error Code:800a000d
- Image to file in Mechanical is bugged and does not show text
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
1436
599
591
591
366
