August 12, 2024 at 2:46 pm
rakibul.buet19
SubscriberHello everyone,
I am trying to simulate Selective Laser Melting in Ansys Fluent. Its a two phase problem. So I am using VOF model.
my domain dimension is :
L = 0.8 mm (X axis)
W = 0.2 mm (Y axis)
H = 0.28 mm (Z axis)
In this domain , I patched the domain ( x = 0.8 mm, y = 0.2 mm , z= 0.2 mm) as solid and the rest is gas.
I am trying to model the heat source as surface heat source and place it at x = 0 mm , y = 0.1 mm and z is undefined as I will use if statement to find the interface ( where 0
My UDF code is given below. After Compiling and initialising , when I try to view the user defined volumetric heat source under the contour tab , FLUENT Crashes instantly. I am not sure what went wrong. Yes I also created 5 user defined memory locations. Can anyone help?
#include "udf.h"
#include "sg_mphase.h"
#include "mem.h"
#include "sg_mem.h"
#include "math.h"
#include "flow.h"
#include "unsteady.h"
#include "metric.h"
// Constants
#define A 0.4 // Absorption coefficient
#define P 200 // Laser power (W)
#define R 40e-6 // Spot radius (m)
#define v 0.5 // Scan speed of laser (m/s)
#define Pi 3.1415926535 // Pi constant
#define x0 0.0 // Initial x position of the laser (m)
#define y0 0.1e-3 // Initial y position of the laser (m)
// UDF for adjusting the gradient heat
DEFINE_ADJUST(adjust_gradient_heat, domain)
Thread *t;
Thread **pt;
cell_t c;
int phase_domain_index = 3.0; // thjats my metal domain
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain, phase_domain_index);
Alloc_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL);
Scalar_Reconstruction(pDomain, SV_VOF, -1, SV_VOF_RG, NULL);
Scalar_Derivatives(pDomain, SV_VOF, -1, SV_VOF_G, SV_VOF_RG, Vof_Deriv_Accumulate);
mp_thread_loop_c(t, domain, pt)
if (FLUID_THREAD_P(t))
Thread *ppt = pt[phase_domain_index];
begin_c_loop(c, t)
C_UDMI(c, t, 0) = C_VOF_G(c, ppt)[0];
C_UDMI(c, t, 1) = C_VOF_G(c, ppt)[1];
C_UDMI(c, t, 2) = C_VOF_G(c, ppt)[2];
C_UDMI(c, t, 3) = sqrt(C_UDMI(c, t, 0) * C_UDMI(c, t, 0) +
C_UDMI(c, t, 1) * C_UDMI(c, t, 1) +
C_UDMI(c, t, 2) * C_UDMI(c, t, 2)); // Magnitude of gradient of volume fraction
end_c_loop(c, t)
Free_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL);
// UDF for defining the heat source
DEFINE_SOURCE(heat_source, c, t, dS, eqn)
Thread *pri_th; // Gas phase
Thread *sec_th; // solid phase
real source;
real x[ND_ND], time;
time = CURRENT_TIME; // Acquire time from Fluent solver
C_CENTROID(x, c, t); // Acquire the cell centroid location
real T = C_T(c, t);
pri_th = THREAD_SUB_THREAD(t, 0);
sec_th = THREAD_SUB_THREAD(t, 1);
real rho = C_R(c,t);
real Cp = C_CP(c,t);
real rhom = C_R(c,sec_th);
real Cpm = C_CP(c,sec_th);
real rhog = C_R(c,pri_th);
real Cpg = C_CP(c,pri_th);
real factor = (2 * rho * Cp) / (rhom * Cpm + rhog * Cpg);
real r = sqrt(pow(x[0] - x0 - v * time, 2.0) + pow(x[1] - y0, 2.0));
if (C_VOF(c, t) > 0.05 && C_VOF(c, t) < 1)
source = ((2 * A * P) / (Pi * R * R)) * exp((-2 * (r * r)) / (R * R))*factor * C_UDMI(c,t,3);
dS[eqn] = 0.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
August 12, 2024 at 3:45 pm
Forum ModeratorWhat if a gradient is negative?
August 13, 2024 at 6:15 am
rakibul.buet19
SubscriberEven if the gradient is negative , I am squaring and rooting the x,y,z gradients and adding them in UDMI 3 right? It aint supposed to be the issue. However when I tried writing the heat source using DEFINE_PROFILE and used begin_f_loop , it worked (although I couldnt add any multiplying factor and gradient UDMI) . I need to multiply the "factor" and "UDMI" in order to convert the surface heat source to volumetric heat source.
CODE : ( This heats up both my gasesous and solid phase , which I dont want)
#include "udf.h"DEFINE_PROFILE(heat_source_profile, thread, position){real x[ND_ND];face_t f;real current_time;real Q = 120; // Define your heat source magnitude (Watts)real rx = 5.3e-5; // Define your desired values for rx, ry, rz (meters)real ry = 250e-6;real rz = 5.3e-5;real A;real vel = 0.1e-3; // velocity @ m/sreal PI = 3.1416;real x_pos;real x_start = 0; // Set your desired starting position in x (m)real y_start = 0.2e-3; // Set your desired starting position in y (m)real z_start = 0.1e-3; // Set your desired starting position in z (m)real x_local, y_local, z_local; // Declare local coordinatescurrent_time = CURRENT_TIME;A = (6 * sqrt(3) * Q) / (PI * sqrt(PI) * rx * ry * rz);x_local = 0.0; // Initialize x_local outside the loopy_local = 0.0; // Initialize y_local outside the loopz_local = 0.0; // Initialize z_local outside the loopbegin_f_loop(f, thread){F_CENTROID(x, f, thread);// Transform global coordinates to local coordinatesx_local = x[0] - x_start;y_local = x[1] - y_start;z_local = x[2] - z_start;x_pos = vel * current_time;// Compute the heat source function valueF_PROFILE(f, thread, position) = A * exp(-3 * (pow(x_local - x_pos, 2.) / pow(rx, 2.) + pow(y_local, 2.) / pow(ry, 2.) + pow(z_local, 2.) / pow(rz, 2.)));}end_f_loop(f, thread)} -
August 13, 2024 at 8:48 am
Forum ModeratorHow would a face loop work on a VOF free surface?
August 13, 2024 at 12:23 pm
rakibul.buet19
SubscriberI have no idea sir :)) But I have worked something out :
I have run the code ( added below) and the heat source part perfectly worked out ( i.e its being applied to where 0
Code :
#include “udf.h”#include “sg_mphase.h”#include “mem.h”#include “sg_mem.h”#include “math.h”#include “flow.h”#include “unsteady.h”#include “metric.h”// Constants#define A 0.4 // Absorption coefficient#define P 200 // Laser power (W)#define R 40e-6 // Spot radius (m)#define v 0.5 // Scan speed of laser (m/s)#define Pi 3.1415926535 // Pi constant#define x0 0.2e-3 // Initial x position of the laser (m)#define y0 0.1e-3 // Initial y position of the laser (m)#include “udf.h”#include “sg_mphase.h”#include “mem.h”#include “sg_mem.h”#include “math.h”#include “flow.h”#include “unsteady.h”#include “metric.h”// UDF for adjusting the gradient heatDEFINE_ADJUST(adjust_gradient_heat, domain){Thread *t;Thread **pt;cell_t c;int phase_domain_index = 3.0; // thjats my metal domainDomain *pDomain = DOMAIN_SUB_DOMAIN(domain, phase_domain_index);Alloc_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL);Scalar_Reconstruction(pDomain, SV_VOF, -1, SV_VOF_RG, NULL);Scalar_Derivatives(pDomain, SV_VOF, -1, SV_VOF_G, SV_VOF_RG, Vof_Deriv_Accumulate);mp_thread_loop_c(t, domain, pt)if (FLUID_THREAD_P(t)){Thread *ppt = pt[phase_domain_index];begin_c_loop(c, t){C_UDMI(c, t, 0) = C_VOF_G(c, ppt)[0];C_UDMI(c, t, 1) = C_VOF_G(c, ppt)[1];C_UDMI(c, t, 2) = C_VOF_G(c, ppt)[2];C_UDMI(c, t, 3) = sqrt(C_UDMI(c, t, 0) * C_UDMI(c, t, 0) + C_UDMI(c, t, 1) * C_UDMI(c, t, 1) + C_UDMI(c, t, 2) * C_UDMI(c, t, 2)); // Magnitude of gradient of volume fraction}end_c_loop(c, t)}Free_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL);}// UDF for defining the heat sourceDEFINE_SOURCE(heat_source, c, t, dS, eqn){Thread *pri_th; // Gas phaseThread *sec_th; // solid phasereal source = 0.0 ;real x[ND_ND], time;time = CURRENT_TIME; // Acquire time from Fluent solverC_CENTROID(x, c, t); // Acquire the cell centroid locationreal T = C_T(c, t);pri_th = THREAD_SUB_THREAD(t, 0);sec_th = THREAD_SUB_THREAD(t, 1);real rho = C_R(c,t);real Cp = C_CP(c,t);real rhom = C_R(c,sec_th);real Cpm = C_CP(c,sec_th);real rhog = C_R(c,pri_th);real Cpg = C_CP(c,pri_th);real factor = (2 * rho * Cp) / (rhom * Cpm + rhog * Cpg);Message(“Factor = %f\n”,factor);real r = sqrt(pow(x[0] – x0 – v * time, 2.0) + pow(x[1] – y0, 2.0));if (C_VOF(c, sec_th) > 0.05 && C_VOF(c, sec_th) < 1){source = ((2 * A * P) / (Pi * R * R)) * exp((-2 * (r * r)) / (R * R))*factor ;dS[eqn] = 0.0;}else{source = 0.0;dS[eqn] = 0.0;}return source;} -
August 13, 2024 at 12:30 pm
rakibul.buet19
SubscriberSorry Something went wrong . I said that , The volume fraction gradient calculation isnt working. Everytime i multiply the term C_UDMI(c,t,2) with source, result becomes 0 . Any chance I might have done any mistake in the DEFINE_ADJUST part?
August 13, 2024 at 12:44 pm
Forum ModeratorNo idea as I don't do much coding and we don't debug. Why not just use the gradients directly?
August 13, 2024 at 1:25 pm
rakibul.buet19
SubscriberIn my code, I am taking value of C_VOF_G . Apparently it seems in order for this to work , I need to set : solve/set/expert/Keep temporary solver memory from being feed? to YES
but, upon doing this I found this message :
Info: Expert option for not freeing temporary solver memory is incompatible with adaption in parallel.
(Also I have used mesh adaption to patch solid domain )
Since, fluent doesnt work in serial in recent days, I need your guidance for storing the VOF Gradient value somehow. Any suggestions?
August 13, 2024 at 1:32 pm
Forum ModeratorYou may have created a register, unless you've set refinement/coarsening you've not adapted the model so you should be OK.
August 13, 2024 at 1:46 pm
rakibul.buet19
SubscriberYes I have created a register and I am obliged to do that for my simulation purpose. As I mentioned earlier, I needed to patch the solid domain to define two different phases. But now I need to calculate VOF gradient of the solid phase. Is there any other way to obtain VOF_G ?
August 13, 2024 at 1:58 pm
Forum ModeratorHave you tried running the solver with the code?
August 13, 2024 at 5:46 pm
rakibul.buet19
SubscriberAll this time I was just checking the contour after initialising. Never really bothered to run the simulation . After running , initially the Gradient was 0 but as soon as I started the sim , it started working!!! THANKS A LOT ROB!! Love you <3
August 14, 2024 at 8:52 am
Forum ModeratorYou'll find some of the UDF calls come at start/end of a time step so it's always worth running before checking output values.
August 22, 2024 at 8:41 pm
rakibul.buet19
SubscriberHi Rob,Thanks for the earlier suggestions. I have finally been able to run the simulation and also been able to visualize the meltpool. (added below)I still haven’t added the Marangoni force equation yet. and for that I need to use temperature gradient value. But I am facing a problem.Here’s a brief summary of my problem :When inside the DEFINE_ADJUST function , I try to add this following line :C_TEMP_G_X(c,t) = C_T_G(c,t)[0] ;After running the simulation fluent crashes instantly. Basically I have renamed the UDMI earlier and now trying to apply the gradient on that UDMI . Any suggestions why is it happening?NOTE : I have alloted sufficient UDMI mannually in the GUII renamed it like that :#include “udf.h”…..…..#define C_TEMP_G_X(c, t) C_UDMI(c, t, 8) // Renaming the UDMIDEFINE_ADJUST(adjust_gradient_heat, domain){… ….C_TEMP_G_X(c,t) = C_T_G(c,t)[0] ; // Applying X axis temp gradient into the renamed UDMI} -
August 23, 2024 at 8:40 am
Forum ModeratorDoes it work if you just use C_UDMI = C_T with all of the (c,t) bits? Making up labels that are similar to something Fluent may use can be a little risky.
August 23, 2024 at 10:08 am
rakibul.buet19
SubscriberI actually figured out the problem. The issue was I forgot to add the below portion inside the DEFINE_ADJUST code. Thanks though !
Alloc_Storage_Vars(domain, SV_T_RG, SV_T_G, SV_NULL);T_derivatives(domain);Free_Storage_Vars(domain, SV_T_RG, SV_NULL);
5669
1890
1419
1304
