TAGGED: added-mass, define-source, dpm, laser-cladding
May 27, 2024 at 5:39 pm
Dubey92
SubscriberHi!! I am trying to model laser cladding in FLUENT. I have designed the system (shown in the image below). It consists of a base substrate surrounded by an inert gas atmosphere from above.
The metal deposition will take place over the substrate as the laser creates a melt pool. The continuity equation has an additional mass source term as shown in the image below:
As I understand, the mass source term will be added under cell zone conditions by changing phase to metal where options for mass source term comes. Please correct me if I am wrong.
Next, I need to deposit metal in the form of powder. This is done through injecting powder using DPM as given in the excerpt taken from a published result.
How to add this source term for the force? Do I use DEFINE_SOURCE or DEFINE_DPM_SOURCE?Â
Any help is much appreciated. Thanks
July 2, 2024 at 2:25 pm
Forum ModeratorAre you melting the solid using a UDF or are you using the solidification/melting model? What are the droplets doing? Ie are the droplets a result of spray from the melt pool or from somewhere else?Â
July 5, 2024 at 5:05 pm
Dubey92
SubscriberÂ
Hi Rob, thanks for your reply. I am melting the solid using a laser (UDF for energy source term and solidification/melting model). Now, I want to add a mass source of the same material. One thing I have understood is that I do not need to add the force terms separately. FLUENT automatically takes care of that.
I just need to add a mass source term in the continuity equation. Can you please tell how to add that? I am unable to understand where to add DEFINE_SOURCE
The droplets fall into the melt pool and solidifiy thus creating a solid layer. As written in the paper, the droplets are inject over the melt pool. I tried using DEFINE_DPM_SOURCE but unable to add a deposit over the solid.
Kindly revert.
Thanks.
- The topic ‘Laser cladding in FLUENT’ is closed to new replies.
6765
1330
1102
