Ansys Products
Ansys Products
Large Fonts size
    • AsadReman
      I was initially using Ansys 2019 R2 but due to some issue i had to uninstall it and install 2019R3. After installing the later version when i opened it the font size of fluent were extra large and no option of setting it right was working. I re-installed the whole operating system (windows) in case files of former version were making some issue and then installed 2019 R3 but the issue still persists. I tried 2020R1 too but same issue. Please somebody kindly help me to resolve it.
      Can you find the %appdata% for Ansys 2019R2 and rename that?
    • AsadReman
      There is only v195 folder related to 2019 R3. I had reinstalled windows(OS) completely before installing 2019 R3
    • tsiriaks
      Open CMD Prompt and enter
      dxdiag
      then post screenshots of the first page and the display tab.
    • AsadReman
      First page
      Display tab 1
      Display tab 2
    • tsiriaks
      Can you try disabling your AMD graphics card ?
      Or, if you want to test it first, what if you just use Display 1 , do you get the same issue ? Also, try only Display 2 and see if you have issue.
Viewing 5 reply threads
  • The topic ‘Large Fonts size’ is closed to new replies.
