Large displacement / plastic strain analysis
    • morrowinter
      Hey,
      Hello, I want to model a part mainly  in bending, in large displacement and with plasticity.
      I implemented the isotropic hardening curve in true stresses.
      Being in large displacements and with plasticity, I believe i should postprocess the cauchy stresses or, I am wrong.
      How can i do that. I only see Von Mises stresses.
      Thanks a lot.
    • Wenlong
      According to the manual (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/ans_elem/Hlp_E_AutoSelectElems.html?q=true%20stress):
      All nonlinear stress/strain data should be input as true-stress/true-(logarithmic-) strain. Accordingly, all output data is also indicated as true-stress/true-strain. For small strains, the true-stress/true-strain data and engineering-stress/engineering-strain data are essentially identical.
      So if you look at Normal stress and Shear stress output, what you get is Cauchy stress (true stress).
      Wenlong
      ================ Note ====================
      If you have trouble opening the links I attached, please see the first useful link below
      Useful Links
    • morrowinter
      Thank you for your answer.
      Is there something like an equivalent cauchy stress or is it still acceptable to postprocess the equivalent VM stress ?
    • Wenlong
      Equivalent stress is V-M stress. It is calculated based on true stress (Cauchy stress) and should be used to compare with the yield stress.
      For more info, please see: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Equiv_Stress.html?q=equivalent%20stress
      Wenlong
    • morrowinter
      Thank you. Everything is clear.
      Best Regards
Viewing 4 reply threads
  • The topic ‘Large displacement / plastic strain analysis’ is closed to new replies.
