April 19, 2020 at 1:51 am
Kevin1993
SubscriberI have problem that when I turned on large deflection in analysis settings the warning messages appear,
but when i turn large deflection to off the warning gone. The problem is large deflection must be turned on to get the correct result.
Is it okay to ignore this or there is something wrong in my model that i need to fix it?
My model is attached in this post.
Thank you
April 19, 2020 at 4:15 am
peteroznewman
SubscriberIt's okay to ignore this warning if you are getting useful results.
April 19, 2020 at 5:15 am
Kevin1993
SubscriberThank you Peter.
- The topic ‘Large deflection warning when turned on’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1414
1221
1118
1015
