October 19, 2023 at 6:24 pm
Mery
SubscriberHi Amrita,
I have the following questions from example https://optics.ansys.com/hc/en-us/articles/18254409091987:
- Locate the 3 .dll files lumhdf5.dll, lumhdf5_hl.dll, and zlib1.dll in the install folder of Lumerical and copy them in the installation folder of Zemax
What exact folder should I copy to these dll's? I copied it to Zemax>DLL>Surfaces as in step 3. Is it correct?
- Open the file metalens_R10mm_f300mm.zprj and see how the metalens is defined
I have the lates Zemax Optics Studio, and when I am trying to open this file, the extension of this file is not in the list. How can I open this file in OpticStudio?
Where can I find lumerical-metalens-XXXX.dll
Thanks!
October 19, 2023 at 6:39 pm
Amrita Pati
Ansys EmployeeHi Maryna,
I haven't actually spent a lot of time on this example. But I think it is referring to the location where the Lumerical installation files are stored. For, exmaple in my case it is in the Program Files. So if you go to Program Files-->Lumerical-->v232 (or if you are using a different relase)--> bin, then you should be able to locate these files (I found them there as well). You can try and let me know if it is not working. I can check with my colleagues in that case.
Amrita -
October 19, 2023 at 6:41 pm
Mery
SubscriberThanks a lot! What about .zprj file and other dll?
October 19, 2023 at 7:10 pm
October 19, 2023 at 7:27 pm
Mery
SubscriberI have the zprj file, I can't open it in OpticSrudio, it doesn't recognize this extension.
lumerical-metalens-XXXX.dll is nowhere to be found.
October 19, 2023 at 7:48 pm
Amrita Pati
Ansys EmployeeThanks for clarifying. Go to the folder where Zemax is installed. Then DLL-->Surfaces. There you should be able to locate the lumerical-metalens-XXXX.dll file. Copy this, paste it in the downloaded folder (making sure it's unzipped). And see if you can now open the Zemax file now. I beileve you can alternatively set the path in Zemax when you open it.
Amrita -
October 19, 2023 at 8:01 pm
Mery
SubscriberThere is no lumerical-metalens-XXXX.dll in the DLL->surfaces. I scanned the computer, and no dll files containing words lumerical-metalens are present on the computer. According to the documentation, zprj file is a database file, and it is not supported by Zemax. A version of the program is OpticStudio R1.03.
October 19, 2023 at 9:23 pm
October 19, 2023 at 9:36 pm
Mery
Thanks a lot for your hard work. I think all the problems come from the older versions of the software I am using.
Kind regards,
Maryna
October 19, 2023 at 10:59 pm
Amrita Pati
You are welcome! I think you are right. I didn't see anything concrete but from some documentations I suspect that you will have to install 2023R2 release of Zemax or newer. I can confirm that with you but it might take me a while. I would suggest you to install the latest version to be on the safe side. But please let me know if that does not work for you.
Amrita -
October 20, 2023 at 3:22 pm
October 20, 2023 at 5:50 pm
Amrita Pati
Sorry you are facing all these issues. I have been busy since this morning. But I will take a closer look and get back to you. Otherwise I will direct you to the Ansys Optical Forum which is more focused on Zemax: ALF-Optical.
Amrita -
October 25, 2023 at 1:02 am
Amrita Pati
I was in touch with my Zemax colleague and she mentioned that the issue has been resolved. Feel free to create a new post if you face any other Lumerical related issues.
Amrita
- The topic ‘Large area metalens example’ is closed to new replies.
