June 28, 2021 at 8:13 am
ciema
SubscriberIs it possible to add in Mechanical constant labels/probes (insensitive to changes) based for example on coordinates?
The problem is that inserting probes manually is problematic. Another problem is that for different results probes sometimes disappears if some changes are made.
Any help will be much appreciated!
June 28, 2021 at 9:54 amciema
SubscriberMaybe some alternative solutions?
June 30, 2021 at 12:08 pm1shan
Ansys EmployeeWhat kind of results are you computing? Results scoped to geometric entities would remain intact unless you change the geometry itself. If you want stress strain results in the geometries interior points then you could use a path/surface construction geometry (at suitable coordinates) and scope results to them. These are insensitive to mesh changes.
Regards Ishan.
Viewing 2 reply threads- The topic ‘Labels/Probes in ANSYS Workbench Mechanical’ is closed to new replies.
5809
