TAGGED: dof, error, overflow, residual, restart-analysis, termination
December 13, 2023 at 3:15 pm
Subhav
SubscriberHello everyone,Â
I am performing a non linear structural analysis in ANSYS workbench 19.1 on my university licenses and I received the following error:
 *** ERROR ***                          CP =   1868.234  TIME= 14:34:55
 The L-2 norm of the residual force overflowed. This may be caused by Â
 PRED,ON or birth/dead elements. Please use PRED,OFF and try again.   ÂÂ
R E S T A R TÂ Â I N F O R M A T I O N
 REASON FOR TERMINATION. . . . . . . . . .DOF LIMIT EXCEEDED                    Â
 RESTART BY RE-RUNNING THE ANALYSIS
 ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.db
 FOR POSSIBLE RESUME FROM THIS POINTÂ
I even entered the command suggested but still the simulation did not work. Since I am using a commercial license there should not be an issue of the number of elements as well which was suggested in one of the older posts.Thanks in advance for your help.
Kind Regards
Subhav Goel
December 19, 2023 at 3:31 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following post helps:
Error static structural non linear simulation (ansys.com)
Ashish Khemka
January 25, 2024 at 12:28 pm
Subhav
SubscriberHi Ashish
I tried the following the steps suggest in the link but even then I am getting the same error.Â
I even tried using the birth/dead element commands but as soon as the second load step starts, I get the same error.Â
How should I proceed.Â
Kind Regards
Subhav Goel
February 23, 2024 at 11:40 am
Ashish Khemka
Forum ModeratorHi,
Please see if the link below helps:
Ashish Khemka
- The topic ‘L2 norm of Residual forces overflowing error’ is closed to new replies.
5824
