June 27, 2023 at 5:42 pm
El Mnif Sirine
SubscriberI am currently using L-PBF Process add-ons for additive manufacturing and I have encountered an issue for which I would need your assistance.
The problem I am facing involves a specific error message that I am receiving while using the software. The error message is as follows: "Tref(1350) is outside of the temperature range defined by the MPTEMP data used for CTEX of material 2". I understand that this indicates that the reference temperature I have used is outside the temperature range defined for material 2 in the MPTEMP data.ÂI would like to know how to resolve this error and ensure that the reference temperature I am using is compatible with the thermomechanical data of the material. Are there any adjustments to be made in the MPTEMP data, or is there another solution to resolve this issue? -
June 28, 2023 at 12:20 pm
Ashish Khemka
Forum ModeratorHi,
Can you extend the range of input material temperature data?
Ashish Khemka
- The topic ‘L-PBF Process’ is closed to new replies.
