February 27, 2023 at 8:10 am
benjamin.pilon
Subscriber​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​​Hello,
when i use copy paste on a body/surface, the copied body/surface do not have the same color propreties (keyshot color) but a regular ARGB code.
I do not have this bug when i copy a part or an assembly.
I have made a little video to help you to understand the issue.
Best regards, Benjamin
February 27, 2023 at 8:31 am
Devendra Badgujar
Forum ModeratorHello Benjamin P.
Thanks for sharing this video to understand this better. I will look into it and get back to you.
Regards.Â
February 28, 2023 at 2:14 am
Devendra Badgujar
I was able to reproduce it at my end, but I can see that this behavior is seen when you are trying to copy and paste the body. When you do this, it takes into account the initial solid object with its material properties. This is same when you have solids in component and try copy pasting that.Â
The possible way to avoid this would be to copy an object using move tool. That is, Press Ctrl to copy the object selected for movement and place it at the location at which you drag or dimension the move.
Let me know if you have further questions on this.
Regards.Â
February 28, 2023 at 2:30 am
benjamin.pilon
SubscriberHello,
Many thanks for your reply !
Does Ansy will continue to work with Luxion ?
It appears that each time i found a bug with Luxion Keyshot, there is no roadmap to correct it ?
Am I right ?
Best regards, BenjaminÂ
February 28, 2023 at 2:46 am
Devendra Badgujar
Forum ModeratorBenjamin P.Â
Let me check with the development team and get back to you. KeyShot 9.3 is the latest version that we support currently.Â
Regards.
March 1, 2023 at 11:12 am
Devendra Badgujar
Keyshot is officially in legacy at this point, I have notified the development about this.
The easier way to avoid this would be to copy an object using move tool. That is, Press Ctrl to copy the object selected for movement and place it at the location at which you drag or dimension the move.
Regards.Â
March 2, 2023 at 2:26 am
benjamin.pilon
SubscriberHello,Â
many thanks for your reply !
I'm not sure to understand well terms like "legacy" does it mean that Ansys will not update this plug-in anymore?
Do you have an equivalent of Keyshot in Discovery ?Best regards, Benjamin
March 2, 2023 at 3:47 am
Devendra Badgujar
KeyShot 9.3 is the latest version that we support currently. As far as I know, there is no equivalent of Keyshot at the moment in Discovery.Â
We do not have more information on this, but I have notified this to the development team.Â
Thank you!
- The topic ‘Keyshot color issue with copy paste on a body’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4597
1495
1386
1209
