Jumping time step in Single Frame Restart simulation
    • John Miller
      Dear forum user,
      I have a small problem with an undesired changing time step in a single frame restart calculation.
      The time step suddenly jumps from 0.1 s to 1s (the default value) in the middle of the simulation.
      After 11 load steps, the time increment jumps to 1 s.
      Although I have set the time with Time, dt..... I have defined a time step of 0.1 s.
      I have already tried to suppress the behaviour of the solver with "autots,off" at various points in the APDL snippet script, unfortunately without success.
      With best regards
      John MIller
    • John Miller
      I use single frame restart, therefore the restart database should be the first load step
      but the solver output indicates something is wrong. In the 12th step something is changing the time step from 0,1s to 1s
      *** ANSYS GLOBAL STATUS ***
       TITLE = ConvRadSURF152Test–Thermisch-transient (E5)
       ANALYSIS TYPE =  TRANSIENT
       NUMBER OF ELEMENT TYPES =      5
           17120 ELEMENTS CURRENTLY SELECTED.  MAX ELEMENT NUMBER =       21920
           58666 NODES CURRENTLY SELECTED.     MAX NODE NUMBER =          58666
              17 COMPONENTS CURRENTLY DEFINED
       MAXIMUM LINEAR PROPERTY NUMBER        =       2
       MAXIMUM REAL CONSTANT SET NUMBER      =       4
       ACTIVE COORDINATE SYSTEM              =       0  (CARTESIAN)
       NUMBER OF SPECIFIED CONSTRAINTS       =   31087
       NUMBER OF SPECIFIED SURFACE LOADS     =    3520
       CURRENT LOAD CASE =      0 OF      0
       LOAD SET   =       1
       SUBSTEP    =       1
       TIME/FREQ  =   0.10000
       INITIAL JOBNAME = file
       CURRENT JOBNAME = file
       RESTART PROCEDURE RE-BUILDS BOUNDARY CONDITIONS
       AND LOADING INFO UPTO THE CURRENT LOADSTEP
       READ ANSYS LOADS DATA FROM FILE= file.ldhi
       DELETE SOLID MODEL BOUNDARY CONDITIONS
       SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
       *** LOAD STEP    11   SUBSTEP     1  COMPLETED.    CUM ITER =     11
       *** TIME =   1.10000         TIME INC =  0.100000      NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  796.3       OSCILLATION LIMIT =  79.63
       FINISH SOLUTION PROCESSING
       ***** ROUTINE COMPLETED *****  CP =        34.109
       LOAD SET   =       1
       SUBSTEP    =       1
       TIME/FREQ  =   0.10000
       NUMBER OF NODAL CONSTRAINTS DELETED                       =     31087
       NUMBER OF ELEMENT CONVECTIONS/HEAT FLUXES DELETED         =      1760
       *** NOTE ***                            CP =      34.953   TIME= 06:49:36
       The number of results set on the restart command is the last set on the
       RTH file.  No updating for the RTH file is required.
       STEP BOUNDARY CONDITION KEY= 1
       REFERENCE TEMPERATURE=   0.000  (TUNIF=  25.000)
       INERTIA RELIEF KEY=  0
       UNIFORM TEMPERATURE SET TO   25.0000000
       ACEL=    0.0000      0.0000      0.0000
       OMEGA=  0.0000      0.0000      0.0000
       DOMEGA=  0.0000      0.0000      0.0000
       CGLOC=  0.0000      0.0000      0.0000
       CGOMGA=  0.0000      0.0000      0.0000
       DCGOMG=  0.0000      0.0000      0.0000
       SPECIFIED CONSTRAINT TEMP FOR SELECTED NODES            1 TO           1 BY           1
       REAL=  30.0000000       IMAG=  0.00000000
       SPECIFIED CONSTRAINT TEMP FOR SELECTED NODES            2 TO           2 BY           1
      SPECIFIED CONSTRAINT TEMP FOR SELECTED NODES        47685 TO       47685 BY           1
       REAL=  70.0000000       IMAG=  0.00000000
       SPECIFIED CONSTRAINT TEMP FOR SELECTED NODES        47686 TO       47686 BY           1
       NONE SELECT  FOR ITEM=NODE COMPONENT=
        IN RANGE         1 TO      58666 STEP          1
                0  NODES (OF      58666  DEFINED) SELECTED BY NSEL  COMMAND.
       NONE SELECT  FOR ITEM=ELEM COMPONENT=
        IN RANGE         1 TO      21920 STEP          1
                0  ELEMENTS (OF      17120  DEFINED) SELECTED BY ESEL  COMMAND.
       *** WARNING ***                         CP =      36.891   TIME= 06:49:38
       Entity 100 is undefined.  The ESEL command is ignored.
      *** ANSYS – ENGINEERING ANALYSIS SYSTEM  RELEASE 2021 R2          21.2     ***
       Ansys Mechanical Enterprise Academic Teaching
       00000000  VERSION=WINDOWS x64   06:49:39  MAR 25, 2023 CP=     37.094
       *** WARNING ***                         CP =      37.109   TIME= 06:49:39
       Material number 5 (used by element 20161) should normally have at least
       one MP or one TB type command associated with it.  Output of energy by
       material may not be available.
       00000000  VERSION=WINDOWS x64   06:49:39  MAR 25, 2023 CP=     37.375
       *** LOAD STEP    12   SUBSTEP     1  COMPLETED.    CUM ITER =     12
       *** TIME =   2.10000         TIME INC =   1.00000      NEW TRIANG MATRIX
       *** RESPONSE EIGENVALUE =  1298.       OSCILLATION LIMIT =  1298.
       ***** ROUTINE COMPLETED *****  CP =        39.297
  • The topic ‘Jumping time step in Single Frame Restart simulation’ is closed to new replies.
