JOINT FORCE ERRORS IN AQWA SIMULATION
    • kingdsystems
      Please was simulating response of FPSO moored (using Soft yoke mooring system allowing articulation at the respective joints) in shallow water of 14m depth using second order wave force (applying QTF). Hydrodynamic diffraction ran successfully with different solution obtained but in Hydrodynamic response in the error shown in this attached image.
      I could not obtain result for the joint forces.
      This is my academic research project and I am stock at this point.
      Please i need your professional advice on what to do.
      Thanks.
Viewing 0 reply threads
