LS Dyna
LS Dyna
Johnson cook strength model not plotting stress/strain graph
    • Tony6
      I am running an explicit dynamic analysis for a car crash and i am using Al 7075 T6. From literature, i was able to obtain the johnson cook parameters for this material.
      The same material in the explicit library uses the steinberg guinan model and produces a perfect stress/strain plot.
      Why cant i produce a similar plot using the johnson cook strength model?
    • Ram Gopisetti
      we see no problem in generatign the curvs on our side given that SG strengh is supressed in same material model.
      waht version of ANSYS adn licence do you hold ?
      Cheers, Ram
    • Tony6
      i am using R18.2 and dont really have the freedom to upgrade it. Is there anything i can do to fix this from my end?
      I noticed you used an explicit material and added johnson cook model, i used general nonlinear material and added the johnson model after. Could that be the reason?
      I could not use an explicit material directly since i am using surface geometry and shell elements
    • Tony6
      Hello, i hope you received my comment and can reply. I would greatly appreciate it as this is very important for my thesis thanks.
    • Ram Gopisetti
      i guess its not true, i could able to get the cuves by having an BISO model as in following image.
      and what do you mean by " I could not use an explicit material directly since i am using surface geometry and shell elements" , there is no elemental limitation for this material model and what licence do you hold ?
      Cheers, Ram
    • Tony6
      When i apply BISO model, it automatically suppresses johnson cook strength and vice versa. They cant work together as they are both different plasticity models. I still cant generate this graph that you have and i dont know how to fix it
Viewing 5 reply threads
  • The topic ‘Johnson cook strength model not plotting stress/strain graph’ is closed to new replies.
