JOB submission on HPC using GPU
    • singh.112
      I am trying to run one of my fluent cases using GPU on our institute HPC server.
      I do submit my jobs using SLURM job scheduler on normal HPC system.
      I just wanted to know what are all the necessary changes has to be made in job scheduler file to run it on GPU.
      This is the sample HPC job scheduler file-
      SLURM FILE
      #!/bin/bash
      #SBATCH --job-name=DiscCounter     # Job name
      #SBATCH --nodes=1                    # Run all processes on a single node
      #SBATCH --ntasks=16          # Run a single task
      #SBATCH --ntasks-per-node=16           # Number of CPU cores per task
      #SBATCH --mem=32gb                    # Total memory limit
      #SBATCH --time=12:00:00              # Time limit hrs:min:sec
      #SBATCH --partition=test   # Queue size small/medium/large
      #SBATCH --output=first_%j.log     # Standard output and error log
      date;hostname;pwd
      module load icc/2023.1.0 mpi/2021.9.0
      /scratch/apps/packages/ansys/ansys_2024/v241/fluent/bin/fluent -g 3ddp -t16 $SBATCH_NTASKS -i transient_journal.jou -ssh -mpi=intel -cnf=$SBATCH_NODEFILE
    • MangeshANSYS
      Hello
      For Fluent refer to the gpu command lie flag documented here
      https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/flu_ug/flu_ug_startramp.html%23flu_ug_sec_startup_option
      For requesting GPU option resources from slurm, you will need to contact your slurm administrator on any specific syntax and guidelines to get the GPU resources assigned
      Let me know if this is helpful
