May 16, 2024 at 6:11 am
gayathrisrid
SubscriberCan someone give some leads on why the following error occurs while running an fdtd simulation.
Job error details:
localhost.localdomain(process 10): Error receiving project file. Buffer stream is empty.
localhost.localdomain(process 10): Error after receiving project file. Stream is in an inconsistent state [failbit or badbit was set]. Check disk capacity of /tmp -
May 16, 2024 at 4:44 pm
Lito
Ansys Employee@Gayathri Sridharan,
Can you provide more information?
- Which operating system and version are you runing on?Â
- Which version of Lumerical FDTD?
- What is the command you use?
- Are you running a script or a simulation file?
- Are you running from the CAD/GUI or the command line?Â
- The topic ‘[Job error] Error receiving project file…’ is closed to new replies.
