March 6, 2024 at 7:40 am
dharanianbu2564
SubscriberHow to model jet breakup by TAB model in ansys fluent. I have tried but it's not working out. I have chosen transient condition. Then enabled vof. phase 1-air,phase2-water, in phase interaction i gave surface tension as 0.072 and in mode transition -vof to dpm. I gave water inlet as 13m/s. Water vol fractn as 1. Method I have used -simplec. But I don't get breakup and droplets results. Can anyone guide me to incorporate both vof and dpm model. Thanks in advanceÂ
March 6, 2024 at 10:23 am
Forum ModeratorPlease can you post what result you're seeing?Â
March 6, 2024 at 11:41 am
March 6, 2024 at 11:48 am
dharanianbu2564
SubscriberHow to get primary and secondary breakup results. How to find the final droplet size which is hitting on the wall.
March 6, 2024 at 2:52 pm
Forum ModeratorI think you need to better resolve the VOF flow first. Once the primary jet break up is visible you can worry about the DPM transition. Don't forget to turn on the dynamic adaption, there's a VOF to DPM preset to simplify things too.Â
March 6, 2024 at 3:31 pm
dharanianbu2564
SubscriberOk will on it. How create 3d animation.I have created animation by creating yz plane. But I need complete 3d animation result. How to create it.
March 6, 2024 at 3:43 pm
Forum ModeratorCheck documentation & Learning - I tend to just create images and then stitch them together afterwards.Â
March 6, 2024 at 3:50 pm
dharanianbu2564
SubscriberOk thank you.
March 7, 2024 at 6:50 am
dharanianbu2564
SubscriberIf possible can you please guide me by creating images on how to view 3d animation results.
March 7, 2024 at 11:18 am
Forum ModeratorIf you have 3d images have a look at what's going on in the flow. At this stage the contours look too smeared to get any break up.Â
- The topic ‘Jet breakup model (vof-dpm)’ is closed to new replies.
