January 25, 2024 at 4:36 pm
saravanakumar saravanakumar.t2022
SubscriberDear sir,Â
I am doing Ph.D. in Heat and Flow Characteristcs of supercritical Fluids in pipe flow. For that, am doing simulation in Ansys FLUENT( paid version --my system is I9 12th gen system] Problem is steady state, K-epsilon model, PISO Algorithm. When comes to iteration, it running for some number of iteration( in my case 92nd iteration) after that no further movement of iteration. it seems stuck but loading. why it happened. I tried same with other system also. same problem coming. i tried with all setting and changing mesh, no use of that. kindly guide me to solve this problem.
Thanking You,
T.Saravana kumar
Ph.D Scholar VIT University, Vellore
March 7, 2024 at 3:32 am
Ashish Khemka
Forum ModeratorHi,
It seems that you have posted a duplicate post. I will close this post and ask team to look into other one: Iteration is not moving…Why? (ansys.com)
Ashish Khemka
- The topic ‘Iteration is not moving…Why?’ is closed to new replies.
4597
1495
1386
1209
