January 25, 2024 at 4:35 pm
saravanakumar saravanakumar.t2022
SubscriberDear sir,Â
I am doing Ph.D. in Heat and Flow Characteristcs of supercritical Fluids in pipe flow. For that, am doing simulation in Ansys FLUENT( paid version --my system is I9 12th gen system] Problem is steady state, K-epsilon model, PISO Algorithm. When comes to iteration, it running for some number of iteration( in my case 92nd iteration) after that no further movement of iteration. it seems stuck but loading. why it happened. I tried same with other system also. same problem coming. i tried with all setting and changing mesh, no use of that. kindly guide me to solve this problem.
Thanking You,
T.Saravana kumar
Ph.D Scholar VIT University, Vellore
March 11, 2024 at 9:33 am
Essence
Ansys EmployeeHello,
What is the mesh count? Are the computational resources you have, sufficient for the simulation you are running?
- The topic ‘Iteration is not moving…Why?’ is closed to new replies.
5824
