August 16, 2020 at 7:48 pm
HG1
SubscriberHi, I tried several versions of Ansys AIM because the program did not work properly. Unfortunately the versions were not completely removed by unistall so that I deleted the remaining files. Now I can no longer install a version, whether older or newer. Is there a solution for that?
August 18, 2020 at 9:43 pmtsiriaks
Ansys EmployeeIs this K drive your local drive or network drive ? I strongly recommend installing ANSYS on a local drive.nTo 'completely' uninstall, make sure you remove the ANSYS Inc folder, delete ANSYS environment variables, and delete the %appdata%\ANSYS folder.nFor the last part, you can just use the following command to quickly do itnmove %appdata%\ansys %appdata%\ansys.oldnNow, try installing it again.nDoes this work ?nAugust 19, 2020 at 3:38 pmHG1
SubscriberAt first I couldn't find the %appdata%\ANSYS folder. But with the following command to quickly do itnnmove % appdata% \ ansys % appdata% \ ansys.old it worked fine. nThank you so much !nCan you possibly explain reason of the error messages in the picture below ?nnn
August 21, 2020 at 10:38 pmtsiriaks
Ansys EmployeeGreat to hear ! Thank you for the update. I'm glad it's working for you.nCheers !nViewing 6 reply threads- The topic ‘Istallation Ansys AIM STUDENT ist blocked’ is closed to new replies.
3862
1414
1220
1118
1015
