December 9, 2022 at 2:23 am
benjamin.pilon
SubscriberHello,
when i click on a body face, i have the possibility to right click then select then body. (see picture above).
But now, if i select two face on two different bodies, this feature comes to grey...
I would have been very usefull if we been able to select multiple bodies like this. Especially when you have to select bodies that are very close to others one you don't want to have in your selection !
I know that we can use triple click on each bodies to select them, but i have usually more than 30 body to select so that mean 30 x 3 clics...Â
Now i'm using the "locate in the tree" feature, then "mask others" and make a huge selection, this is a little bit heavy...
Best regards, Benjamin
December 9, 2022 at 2:30 am
Charudatta Bandgar
SubscriberHello Benjamin P.
Let me check this, will get back to you.
Regards.
December 9, 2022 at 3:10 am
December 9, 2022 at 4:12 am
benjamin.pilon
SubscriberHello Charudatta Bandgar ,
many thanks for your reply !
I'm actually using 2022R1, so i will ask for a software update to the IT of my company and get back to you asap.
March 29, 2023 at 8:48 am
benjamin.pilon
I have finally got the 2022R2 installed on my computer and unfortunately i encounter the same issue...
After some tries, i have found that i need to do the right click on a selected surface to show the menu.
Below with right click on one of already selected face "in orange" :
Below when i do a right click elsewhere :
But once done, only one body is selected.... (The body wich i have made a right click on ....)
Is it possible to correct this issue in the next patch ?
- The topic ‘Issues with the body selection feature’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4613
1515
1386
1209
