July 11, 2025 at 10:14 pm
HL
SubscriberHello, I would greatly appreciate some help with this. I am modifying an official LS-DYNA example, Underwater F (https://lsdyna.ansys.com/underwater-f/), to instead have a square field that is constructed with an S-ALE mesh. Everything else stays the same, so the resulting simulations should look identical for the first ~30 time steps, until the shock wave reaches the boundary of the cutout in the example. However, they look different and the shock wave is not propagating outward into the water and it looks like there is a boundary effect.
I created an S-ALE mesh and a box region at the bottom left corner (the origin). I filled the entire region with water and then the box region with the explosive material. I detonated the material at the origin at time 0.
1. There seems to be some kind of boundary effect at the box region. I don’t think I defined any boundaries and am wondering if there is a discontinuity or something between the two materials. However, I don’t know how to fix this, particularly with this S-ALE method.
2. Originally, I kept the element sizes the same, 1 element = 1 cm. However, for my simulation, the velocity contour did not show the shock wave, which was very strange, so I refined the mesh to have each element be 0.16 cm. Now I can see the shock wave, but it is strange that this refinement was not necessary for the official example but was for mine. Would anyone know why this might be?
Please, I would greatly appreciate some help, thank you very much in advance.
Here is my code:Â
*KEYWORD*NODE    1 0.000000000E+00 0.000000000E+00 0.000000000E+00    2 0.000000000E+00 0.000000000E+00 0.000000000E+00    3 0.100000000E+00 0.000000000E+00 0.000000000E+00    4 0.000000000E+00 0.100000000E+00 0.000000000E+00*ALE_STRUCTURED_MESH_CONTROL_POINTS   1001          1    0.0         51    8.0         201   32.0*ALE_STRUCTURED_MESH_CONTROL_POINTS   1002          1    0.0         51    8.0         201   32.0*ALE_STRUCTURED_MESH_CONTROL_POINTS   1003          1    0.0          2    1.0*DEFINE_COORDINATE_NODES    234     2     3     4*ALE_STRUCTURED_MESH     7   5000   10000   10000   1001   1002   1003     1    234  Â*DEFINE_BOX     9    0.0    8.0    0.0    8.0    0.0    1.0*PART     1     1     1     1*PART     2     2     2     2*MAT_NULL     1    1.0*MAT_HIGH_EXPLOSIVE_BURN     2   1.63   0.784   0.260 0.000E+00*EOS_GRUNEISEN     1    1.5Â*EOS_JWL     2   3.71 3.230E-02   4.15   0.950   0.300 4.300E-02   1.00*ALE_STRUCTURED_MULTI-MATERIAL_GROUP   water     1     1   expl     2     2*ALE_STRUCTURED_MESH_VOLUME_FILLING     7        water    ALL*ALE_STRUCTURED_MESH_VOLUME_FILLING     7        expl  BOXCOR     0     9*CONTROL_ALE     0     1     2   -1.0Â*CONTROL_ENERGY     2     1     2     2*INITIAL_DETONATION   5000 0.000E+00 0.000E+00 0.000E+00 0.000E+00*CONTROL_TERMINATION   100.0*DATABASE_BINARY_D3PLOT    1.0*DATABASE_GLSTAT    0.1*ENDÂAnd here are the screenshots of the pressure contours: -
July 14, 2025 at 9:25 am
Forum ModeratorDuplicte https://innovationspace.ansys.com/forum/forums/topic/issues-with-modifying-official-ls-dyna-ex-with-s-ale-mesh/
- The topic ‘Issues with modifying official LS-DYNA ex with S-ALE mesh’ is closed to new replies.
5884
1306
