February 7, 2023 at 10:09 pm
oelagab
SubscriberHello,
I am very new to the Ansys fluent, I am following a tutorial direction to simulate solid particles flow ( Discrete phase) with air flow ( continuous phase), I am using the default parallel one processor in the calculation and takes me about 4 hrs to complete the calculation.
number of time steps: 6000Â Â time step : 0.01Â Â iteration 20
please help me to figure this out starting with the very basics stuf since i am very new to it.
Thanks,
Oubai
February 7, 2023 at 10:40 pm
peteroznewman
SubscriberHow many cores does your computer have?
February 8, 2023 at 1:38 pm
Forum ModeratorYou may also want to check RAM usage, the solver tends to slow down if you're paging to disc. I'd be surprised if that's the case, but it'll depend on how new your PC is.Â
February 8, 2023 at 7:22 pm
oelagab
SubscriberThank you guys for the quick replies and my computer has 10 cores and 12 logical processors, and my PC is very new with a 1TB SSD and 16 RAM, but i don't know what do you mean by paging to disc can you please let me know how to fix that if that is the case.
Thanks
February 9, 2023 at 9:37 am
Forum ModeratorPaging to disc is when the solver runs out of RAM and starts using disc cache. It used to be obvious as the discs made a noise. With 16GB RAM you should be OK with 5-8M cells.Â
- The topic ‘Issues with long time of calculation ( 4 hours)’ is closed to new replies.
