Photonics
Photonics
Issues with getting result from interconnent analysis script
    • 21307110070
      As shown in the figures, why is the value I defined in the analysis script in INTERCONNECT not outputting in the results(the obj is empty), while the same operation works in FDTD? How can I output the values calculated in the analysis script in INTERCONNECT to the results?
      Thanks!
    • Dev
      Aplogies for delay in response. In order to understand better can you please share some more details. What device are you simulating? are you using any of the application galary example?
      Is it possible to share the analysis script as well.
      Thanks
    • 21307110070
      Hello, thank you for your reply. The issue should not be related to the simulation device and code I am running. The problem is as follows: I defined the value of obj in the script of the interconnect analysis and added this variable in the output options, but the obj I obtained after the program ran is still empty. However, the same operation is performed in FDTD, where the script in FDTD analysis defines the value of T_avg. After the program runs, the value of T_avg can be obtained. Do I need any additional operations in interconnect to obtain the value of the variable in the script of the analysis?
    • Dev
      Which version of software are you using? I want to make sure its the recent version.
      Also can you update your ALF account with your name rather random numbers? It will help us to address you with a name.
      Best regards
