Issues with 3D Wave Rotor Simulation in ANSYS Fluent
    • ar097dr
      Hi everyone, I’m working on a 3D simulation of a wave rotor in ANSYS Fluent Student Edition. To simplify the computation, I’m taking advantage of symmetry and simulating only half of the rotor. I’ve attached screenshots showing the geometry and mesh for clarity.    Problem: When I run the simulation using the pressure-based solver, I encounter a Floating Point Exception error. If I switch to the density-based solver, I get a different error: Node 1 Fatal signal raised sig = Segmentation fault
       b3f1c3a0 CX_Primitive_Error
       ffd881f0 seh_filter_exe
       b3fc24d0 logical_right_shift
       e41be720 _C_specific_handler
       23e3dc0 _chkstk
       229e8c0 RtlWow64GetCurrentCpuArea
       23e3770 KiUserExceptionDispatcher
       b1c7c530 Partial_Slip_Thermal_Coef
       b3746890 Multi_Stage
       b3746200 Solve_Coupled
       b16beb80 alloc_mp_drag_coeff
       b0df6c40 Models_Send_update_solve
       b15ede90 solver_update
       b15ea0f0 Flow_Iterate
       b0cb8b00 CX_Disable_Interrupts
       b3fac470 eval
       b0dd0150 PRF_Command_Start
       b0dd2880 PRF_Node_repl
       b0dde690 Delay_Error
       98e8c0 BaseThreadInitThunk
       235fba0 RtlUserThreadStart
      What could be causing these errors in both solvers? Are there specific adjustments I should make for a half-geometry simulation using symmetry? How should I proceed to ensure the simulation runs without errors? Any guidance or suggestions would be greatly appreciated! Thanks in advance for your help!
      Where is the fluid going? I'm not sure what you're trying to model, but if it's a rotor where's the stationary bit, and how is the flow symmetrical?
      • ar097dr
        So basically the inlets and the outlets are located in the two stationary plates as you can see in the screenshot below. The other one is the rotating rotor with his channels.
        For the symmetry, I'm talking about the fact that my geometry is cut in half because it is periodic and so around the circumference the same condition apply twice. Do you know why i keep getting those errors?
      So, you've got two sets of rotational periodic boundaries and two pairs of non-conformal interfaces?
      • ar097dr
        Basically yes
      Are you looking at temperature too?
      • ar097dr
        Yes the periodic boundaries conditions are in terms of pressure and temperature.
      Turn off rotation. What happens? If that fails turn off periodic, then try. Something isn't set up correctly, but the best way to figure out what that is is to turn things off until it works.
      • ar097dr
        So I turned off rotation and periodic leaving on only the boundary condition, then launched the simulation. If pressure based this is the error that pop up:
        Updating solution at time level N...
        done.
        iter continuity x-velocity y-velocity z-velocity energy time/iter
        1 1.0000e+00 1.0538e-02 8.4763e-03 2.2343e-02 6.7692e-04 0:00:15 19
        Reversed flow on 203 faces (53.9% area) of pressure-inlet 27.
        Reversed flow on 348 faces (99.8% area) of pressure-inlet 28.
        Reversed flow on 36 faces (9.7% area) of pressure-outlet 29.
        Reversed flow on 175 faces (48.9% area) of pressure-outlet 30.
        Stabilizing pressure correction to enhance linear solver robustness.
        Stabilizing pressure correction using GMRES to enhance linear solver robustness.
        Divergence detected in AMG solver: pressure correction
        Error at host: floating point exception
        If density based this is the error:
        Node 0 Fatal signal raised sig = Segmentation fault
         791bc3a0 CX_Primitive_Error
         c89481f0 seh_filter_exe
         792624d0 logical_right_shift
         adaae720 _C_specific_handler
         cad83dc0 _chkstk
         cac3e8c0 RtlWow64GetCurrentCpuArea
         cad83770 KiUserExceptionDispatcher
        Any idea on how to fix it?
      Unless flow is doing about Mach 5 don't use Density based. There are exceptions, but I very much doubt you're modelling one of those!
      Why pressure in and pressure out?
      • ar097dr
        Yes the flow is subsonic. Pressure in and out because my boundary condition impose certain pressure and temperature conditions on the inlet and outlet ports
      Try fixing the flow and see how it behaves. Trouble shooting means eliminating potential problems and velocity in means you must see flow.
      • ar097dr
        Sorry I'm afraid I do not understand what are you asking me to do
      Try using a velocity inlet. Initialise from that boundary and run a few iterations. What happens?
      • ar097dr
        So I tried with velocity inlet, bust still breaks in the first time step after few iteration. I’ll copy the console report below:
        Updating solution at time level N…
        done.
        1 1.0000e+00 1.3271e-02 1.1309e-02 1.4667e-02 6.6454e-03 0:00:00 19
        Reversed flow on 81 faces (20.9% area) of pressure-outlet 29.
        Reversed flow on 167 faces (46.7% area) of pressure-outlet 30.
        2 1.0000e+00 2.0676e-02 2.7264e-02 4.8245e-02 2.2009e-03 0:00:18 18
        Reversed flow on 115 faces (30.4% area) of pressure-outlet 29.
        Reversed flow on 18 faces (5.4% area) of pressure-outlet 30.
        3 1.0000e+00 2.7187e-02 3.6026e-02 1.2450e-01 8.4653e-03 0:00:14 17
        Reversed flow on 32 faces (8.4% area) of pressure-outlet 29.
        Reversed flow on 25 faces (7.1% area) of pressure-outlet 30.
        4 1.0000e+00 1.2537e-01 1.3589e-01 2.0873e-01 6.4304e-03 0:00:10 16
        Reversed flow on 19 faces (5.7% area) of pressure-outlet 29.
        Reversed flow on 13 faces (3.5% area) of pressure-outlet 30.
        Stabilizing enthalpy to enhance linear solver robustness.
        5 1.0000e+00 7.1412e-02 3.1269e-03 1.1736e-03 2.9869e-01 0:00:08 15
        Reversed flow on 56 faces (15.7% area) of pressure-outlet 29.
        Reversed flow on 45 faces (13.4% area) of pressure-outlet 30.
        Stabilizing x-momentum to enhance linear solver robustness.
        Stabilizing y-momentum to enhance linear solver robustness.
        Stabilizing z-momentum to enhance linear solver robustness.
        absolute pressure limited to 5.000000e+10 in 18 cells on zone 17
        absolute pressure limited to 5.000000e+10 in 1 cells on zone 18
        6 6.3736e+07 3.8551e-02 2.4861e-05 6.7488e-07 2.3187e-01 0:00:09 14
        Reversed flow on 190 faces (51.9% area) of pressure-outlet 29.
        Reversed flow on 52 faces (14.8% area) of pressure-outlet 30.
        Stabilizing enthalpy using GMRES to enhance linear solver robustness.
        Divergence detected in AMG solver: enthalpy
        absolute pressure limited to 5.000000e+10 in 20 cells on zone 17
        absolute pressure limited to 5.000000e+10 in 6 cells on zone 18
    • ar097dr
      P.S. It breaks even if I just set test value of velocity at SL condition
      OK, so what do the velocity contours look like at iteration 2 and 3? Trouble shooting means more than just reading the console output.
      • ar097dr
        The point is that Fluent does not generate the animation to show the velocity contour. I tried using the Results section in Ansys, but I'm not very good at it. Do you have any tips?
      Use Fluent. Create an isosuface (Mesh > Radial Coordinate I think) and plot on that. Just initialise and display run an iteration & repeat. If you're using Workbench, don't, and run Fluent in standalone mode.
Viewing 10 reply threads
