June 3, 2024 at 3:47 am
Deep Kalsariya
SubscriberHello
Can anyone help me with issues I am facing while creating metasurfaces in HFSS?
How can I change the distance between two unit cells?How do I implement different unit cells in one metasurface?
What is the process for designing a phase gradient unit cell?How can I create a digitally coded metasurface?
July 23, 2024 at 12:24 pm
Praneeth
Ansys EmployeeHi Deep,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
If you are new to unit cell analysis, I suggest you go through example designs under the Metamaterial folder of "open examples". You can also go through this free AIS course on using Floquet ports along with coupled boundaries -Â Ansys HFSS Floquet Port | Ansys Courses.
Please find my response to your questions as follows:Â
How can I change the distance between two unit cells? - If the unit cells of your design are not touching one another, you can include the gap between the unit cell geometry and the coupled boundary.
How can I create a digitally coded metasurface? - Please provide more details to help us serve you better.Best regards,
Praneeth.
- The topic ‘Issues while creating metasurface in HFSS’ is closed to new replies.
