September 14, 2022 at 4:55 am
miratip
SubscriberI am trying to run Fluent on my school's supercomputer with multiple cores. When I do this, however, the results are somewhat erroneous. Essentially, there are certain grid points where the solution is zeroed out (shown in the figure). I am assuming these locations are where the domain is split up between the cores. This issue does not occur when I run only using one core.
Anyone seen this before or have any idea how to fix this?
Thanks.
September 14, 2022 at 8:49 am
Forum ModeratorAre the results showing the problem in Fluent too? Just trying to narrow down if it's the data or whatever you're exporting & reading into.Â
September 15, 2022 at 5:59 pm
miratip
SubscriberThanks for your response. I will spend some time trying to figure out how to assess my results in Fluent and get back to you.
September 15, 2022 at 11:25 am
DrAmine
Ansys EmployeeProbably issue with the export. Try to assess the results inside Fluent first.
September 15, 2022 at 5:58 pm
miratip
SubscriberThanks for your response. I am not using the Fluent GUI so I'll have to spend some time figuring out how to assess my results within Fluent.Â
Is there a reason why the export would work fine with one core but have issues with multiple cores?
September 16, 2022 at 9:25 am
DrAmine
Ansys EmployeeBugs are always possible even in the post-processing module you are using. Check the results in Fluent first and let's know if you see issues there too. If yes then it has nothing to do with export!
September 27, 2022 at 11:42 pm
miratip
SubscriberOk, the results look fine within Fluent so it seems the problem is with the export. Any ideas what could be going on?
September 28, 2022 at 8:22 am
Forum ModeratorWhich export option are you using? Check the export limitations, and also check how the post processing tool handles duplicate points.Â
October 19, 2022 at 7:44 pm
miratip
SubscriberHere is the command I use to set up the export:
/file/transient-export/ascii result_file () x-velocity y-velocity pressure phase-water-vof () no no export1 time-step 10 time-step
How would I check the export limitations? Also for post-processing I am just using a script that I wrote. I don't think there are duplicate points being exported because the number of nodes written out matches the number of nodes in my mesh.
September 28, 2022 at 3:58 pm
DrAmine
Ansys EmployeeYour Export Format? ASCII?
October 19, 2022 at 7:45 pm
miratip
SubscriberYes, ASCII. Would a different format work better?
October 20, 2022 at 11:34 am
DrAmine
Ansys EmployeeIf the values from ASCII Exports do make a sense then I will suspect the post-processor of these values given the root values from Ansys Fluent are correct. Have you tried with another format your tool does sustain?
October 20, 2022 at 3:55 pm
miratip
SubscriberThe values from the ASCII exports don't make sense; the solution is zeroed out at certain points resulting in the weird structures seen in the image in my initial post. This is the crux of my issue.
October 21, 2022 at 6:55 am
DrAmine
Ansys EmployeeCan you reproduce the problem on a dummy example so that we are able to do the same on our side? Is your case 2D planar?
- The topic ‘Issues running Fluent across multiple cores’ is closed to new replies.
5819
