April 4, 2023 at 9:57 am
Shane Jumper
Bbp_participantNeed immediate help i can not log in to SC. saying there is no valid license
April 4, 2023 at 10:24 am
Atharv Joshi
Forum ModeratorHello Shane Jumper
I don't any active devices for your Ansys Discovery Modeling (Named User License). Can you please activate the license using your login credentials.
If that doesn't work, please try activating the license using command prompt and then try launching the application.
Please refer Discovery Subscription license - Command line options for instructions on activating licenses through command line.
Let me know if this resolves the issue for you.
Thanks and Regards
April 4, 2023 at 2:04 pm
Shane Jumper
Bbp_participantJosh call me when you have a chance im still having no luck
April 5, 2023 at 1:01 am
Atharv Joshi
Forum ModeratorHello Shane Jumper ,
Can you please confirm that you are using the correct installer Discovery Downloads - Knowledge Base - Ansys Discovery Forum. If not please, try downloading the new installer and activate the license.
Please share the screenshot of the error you are seeing.
Thanks and Regards
- The topic ‘Issues on log in’ is closed to new replies.
5649
1885
1404
1303
