February 10, 2023 at 10:53 pm
rachael.auch
SubscriberHello,
Attempting an installation of Ansys 2023 R1 on CentOS 7 and we are receiving the following error:
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.Any suggestions are appreciated. Thank you.
February 15, 2023 at 10:55 am
ansysaccount
SubscriberOn my CentOS 7 installation the packages xcb-util-wm xcb-util-renderutil were missing.
To diagnose such Problems in general set
export QT_DEBUG_PLUGINS=1
before starting the INSTALL script.
In my case i got
Cannot load library /tmp/ans_install_tmp20326/platforms/libqxcb.so: (libxcb-icccm.so.4: cannot open shared object file: No such file or directory)
QLibraryPrivate::loadPlugin failed on "/tmp/ans_install_tmp20326/platforms/libqxcb.so" : "Cannot load library /tmp/ans_install_tmp20326/platforms/libqxcb.so: (libxcb-icccm.so.4: cannot open shared object file: No such file or directory)"The missing libxcb-icccm.so.4 is part of the xcb-util-wm Package.
- The topic ‘Issues installing Ansys 2023 R1 on CentOS 7’ is closed to new replies.
3712
1313
1163
1090
1014
