TAGGED: export-result, fluent, static-pressure, static-structural
October 4, 2020 at 2:32 pm
helen.durand
SubscriberHello!
I am having inconsistent results when exporting static pressure results from fluent to static structural. Sometimes it has worked, but usually is yields profiles such as the following. I was wondering if anyone know why this might be occurring and how address it?
October 5, 2020 at 1:43 pmRahul Kumbhar
Ansys EmployeePlease check if the units systems are consitent. IN first image the max pressure value appears very different than the second imagenOctober 6, 2020 at 1:01 pmhelen.durand
SubscriberThank you, rkumbhar.nThe unit systems are consistent, but this does not appear to be the issue.nThe reason why the first image has low pressure values is because I imported the dynamic pressure. Sorry, it was confusing to include this image.nA better image, where I imported the total pressure, is below. I have similar issues with static pressure.n
n
Viewing 2 reply threads- The topic ‘Issues importing Fluent pressure results into static structural’ is closed to new replies.
4803
1582
1386
1242
