Electronics
Electronics
Issues exporting as .dxf in HFSS
    • Carson Moseley
      I am attempting to export as a .dxf in HFSS, but regardless of how I go about it, I am only given graphics options (image formats only). The Help manual just says to use Modeler --> Export, but that clearly is not working in my case because it is being treated as a graphic when it is a 3D model. What settings do I need to change / adjust to remedy this?
    • Jason.k
      Hello Carson,
      The option of exporting to .dxf (and other formats, let’s say .gds .obj etc.) your 3D model,  should be available following the process you describe.
      Let me ask a question; What version of HFSS do you currently use? Is it a student version?
      Kindly,
      Jason.
      • Carson Moseley
        Hi Jason,
        Thanks for your reply. I'm currently using the latest release of the student version. Is this a limit of the student version? I was having trouble finding documentation on the differences of versions so I couldn't confirm for myself.
        • Jason.k
          Hi Carson,
          Unfortunately, the option to export a model as .dxf file in the student version isn’t available.
          Kindly,
          Jason.
  • The topic ‘Issues exporting as .dxf in HFSS’ is closed to new replies.
