October 25, 2024 at 4:16 am
chuminhkhue
SubscriberI am trying to solve the transport equation for a user-defined scalar (UDS) representing the number of particles in a single-phase flow, with velocity at the inlet and zero pressure at the outlet. The flux function I am using is the mass flow rate.
At the inlet, the particles are released at a rate specified as the number of particles per unit area per unit time (flux). The inlet concentration of RP is 2.5 × 10^14 particles/m³ and the inlet concentration of AP is 1.25 × 10^13 particles/m³.
I am defining the specific flux at the inlet as:
-1 × UDS diffusivity × grad(UDS) ⋅ nwith units of kg/(m⋅s) × particles/m³ × m⁻¹.
i conduct it by ufd profile like this
When I apply this specific flux model, my simulation crashes. However, when I set a specific value of 2.5 × 10^14 for RP and 1.25 × 10^13 for AP at the inlet, it runs but I am unsure if it is working correctly.
Can you help me understand why the specific flux model causes the crash and whether I am correctly setting up the boundary conditions for the UDS?
October 29, 2024 at 3:04 pm
Forum ModeratorIf you're using scalar gradients have you told Fluent to retain all values? Can't remember the exact term off hand, but there's a TUI command to avoid some gradients etc being discarded following their use in the calculations. It'll be covered in the Scalar bit of the manual if it's necessary.
October 29, 2024 at 4:14 pm
thamilmani
Subscriber/solve/set/expert no no yes no
October 30, 2024 at 4:48 am
chuminhkhue
SubscriberThanks for your reply
April 18, 2025 at 1:37 am
Anthony Bowers
SubscriberHello,
Did you get any success with this task?
