September 12, 2021 at 1:29 pm
Christopher Willett
SubscriberI am trying to model a composite plate with SOLID186 layered structural elements in ANSYS Workbench - Mechanical. I wish to partition the geometry into multiple solid volumes (completed via "slice" in design modeller); however, when I partition the geometry into multiple solid bodies I am encountering an issue with element orientation when issuing commands for a layered section for each solid body via APDL commands.
I add the following commands to each solid body of the plate geometry:
ET,MATID,SOLID186
KEYOPT,MATID,3,1
KEYOPT,MATID,8,1
SECTYPE,MATID,SHELL
SECDATA,0.3E-3,MATID,0
SECDATA,0.3E-3,MATID,90
SECNUM,MATID
These are the resulting element triads:
September 15, 2021 at 1:44 pmGovindan Nagappan
Can you use command objects to plot the results in layer coordinate system
I see that your plot says "LAMINATE CS", but you are defining the orientations using commands. The LAMINATE CS you create in Mechanical under "coordinate system" probably doesn't match the orientation for each element defined in command object
Viewing 1 reply thread- The topic ‘Issue with element orientation when using APDL command for layered section of solid elements’ is closed to new replies.
4618
1530
1386
1209
