April 9, 2020 at 9:00 pm
DavidSzonyi
SubscriberHi,
When trying to create a video inside Mechanical by hitting the export video file button, the saved video only shows a very close up view of the top left of the view port (picture below). I've tried playing with the graphics options (increasing the video height and width) but it doesn't change anything. I'm not sure but maybe this issue has something to do with the fact that i'm running ANSYS in 4K resolution. Any help would be greatly appreciated.
Cheers,
David
April 10, 2020 at 12:26 am
peteroznewman
SubscriberIf you set the display resolution to 1920x1080 I expect you will get a normal video output.
April 10, 2020 at 1:52 am
April 13, 2020 at 8:47 pm
peteroznewman
SubscriberSee if there are settings in the 3D graphics card driver that you can tweak.
April 13, 2020 at 9:04 pm
DavidSzonyi
SubscriberI found the issue, I had "Disable display scaling on high DPI settings" selected in the ANSYS Workbench properties window. I had this turned on to help run ANSYS in 4K. Found that info here:
/forum/forums/topic/installation-issues/
I turned it off and went to 1920x1080 and it seems to work now. I'll have to run ANSYS in 1920x1080 from now on but at least it works!
Thanks,
David
- The topic ‘Issue with creating an animation video’ is closed to new replies.
3587
1193
1086
1068
952
