The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Issue with contour discontinuity while using dynamic mesh.
    • z5456415
      Hi all,
      I am encountering an issue with contour plots for a pitching airfoil simulation (using a dynamic rotating mesh). The contour shows a discontinuity between the dynamic mesh zone and the background mesh. Please refer to the attached image for clarity.
      Additionally, the contour plot displays the edge of the dynamic mesh zone, even though I did not select it when defining the contours.
      Can anyone please assist me in resolving this problem? I am saving the contours at each time step by defining an animation under Solution Animations (in Calculation Activities) and exporting them as JPEG or PNG files. Would using ANSYS Ensight for postprocessing help address this issue after saving the files as HSF?
      I also tried selecting only the background mesh and airfoil boundaries (excluding the dynamic mesh zone), but this created a gap (an empty region) between the airfoil boundary and the background mesh in the plot.
      I need to use the dynamic mesh option for this simulation because I plan to simulate passive airfoil motion later (the current simulation shows active motion).
      Any suggestions would be greatly appreciated!
      Muhammed Sadique
      Please can you post an image of the mesh and also velocity contour.
    • z5456415
      Hi Rob,
      Thank you very much for you reply.
      Here are the images,
      Overset?  How does the contact look, ie how many orphan cells are there?
